My PC has had a lot of problems lately. it started about 4 months ago with my PC just randomly freezing and shutting down, I thought it was annoying but ignored it since it only really happened like one a week at most. but in the last two months, I can barely run my pc for any extended period of time without it shutting down ( we are talking 1-3h at best). After some time I figured out that it would shut down when put under stress, like when I was playing games. I ran it through FurMark and Aida64 Extreme without any issues. But when running them both at once, it would consistently cause the PC to crash. I looked up a solution to my problem at found that it was usually a damaged PSU that caused these kinds of issues. So I got a new one from Corsair and thought I was good to go. Nope, still the same problem as before. My PSU was very old (4-5 years) so is it possible that it may have damaged some other components?
Specs
OS: Windows 10 64 Bit
CPU: AMD FX-9590 4,7 Ghz
GPU: ASUS ROG GTX 1060 6GB Strix
MOBO: ASUS M5A99FX PRO R2.0
CPU Coller: Swiftech H220
RAM: 24G (8*3)
PSU: Corsair VS550
Mobo and GPU drivers are all up to date
Specs
RAM: 24G (8*3)
PSU: Corsair VS550
