Randomly Get Lines Going Through Monitor?
Friendlyx
63
I just got myself an LG Monitor and i've been noticing that i get lines across the monitor a few times a day. I'm not even doing something that may be considered hard on the gpu or anything, just browsing the web. I've included pictures, is there any reason why?
https://ibb.co/kFQ3Tk
https://ibb.co/bARSok
Friendlyx
63
I just got the monitor too, so i hope it isn't it. I used to have a 1440p and now this is 4k, and i have it connected through
a displayport cable.
Friendlyx
63
It usually only happens when just on my chrome and stuff, browsing the web. I have an GTX 1080 Ti by the way.
it could be a bad display port cable. maybe check to see if it acts that way if you go into the BIOS. i know it happens randomly so that may be difficult to reproduce like that
junii421
Notable
Feb 27, 2017
321
1.Could be a bad video adapter.
2. your motherboard needs vertical sync
3. gpu is dying slowly while you cry
4. Monitor is broken?
Friendlyx
63
I wasn't able to reproduce it in bios, i changed the cable the day i spoke to you last, and it hasn't happened since, however, today i started my computer and went to take my sister to school, and came back it was with lines again. I don't know if it's the monitor, because like i said in my old 1440p monitor it never happened to me. Any more ideas?
