Rapid beeping and weird memory issues. HELP!
malrats
37
I had this issue when I first built my PC a few years back but ultimately had it "resolved" until last night
The motherboard is very, very weird about how I put the sticks of RAM in and I guess even the order I put them in. If it didn't like the way I put them in (4x4gb) then it wouldn't POST and instead beep rapidly, reboot, beep rapidly, and repeat the cycle endlessly.
I've got two different brands and speeds (1600 and 1333, I guess) and I keep the pairs together in slots 1/2 and 3/4. Suddenly last night I kept getting BSODs like crazy, then finally I was getting one when trying to boot, then Windows 10 said it needed a startup repair. Then somehow it just started working again, but I did a memtest86 pass and I got a ton of errors on test 4.
So today I took the sticks out and have been trying to get them in to the point where it POSTs and then running memtest86 each time. 0 errors on each test. And now I can't get all 4 sticks back in. In fact, I can't even seem to get two back in. I just had 2 in slots 3/4 and got it to POST and was running the memtest, and while typing this just now it actually just shut down, restarted, and did the crazy beeping and now won't POST again
Any ideas?
I ordered a 16gb RAM kit last night that comes in tomorrow, assuming based on the errors that it was bad memory needing replacing
The motherboard is a Gigabyte G87X-UDH3. Based on what I can find, the rapid beeping with this motherboard is an issue with the memory.
