Raptor - A7N8X-E problem, Need Help
G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
I turned on my new machine, to install Windows XP in a new Raptor (with no
other drives). I loaded the SATA driver, went as far as beginning to
partition the drive, made the first partition ok, then while I was making
the next partition, I _think_ that I pushed some wrong key, stuff happend
very fast so I'm not sure what went on right next, and I turned off the
machine. Now when I turn it on again, it boots up to showing "Verifying
DMI Pool data..." on the screen, and then "error loading operating
system" and stops there.
There is, of course, no operating system yet. I tried to get past that in
every way I could think, to no avail.
I next added a PATA HD with Win98 on it, and looked at the Raptor from
Win98. I got a box saying "G:\ is not accessible. A device attached to
the system is not functioniong"
I don't have another machine running SATA to try the Raptor on. I ran out
of ideas, so any suggestions about what may have happened, and where to go
from here, will be most appreciated.
G
Guest
Guest
Set the CD drive to be the first boot device and boot the Windows XP CD.
G
Guest
Guest
In article <10mpvjbo83uce86@corp.supernews.com>, dNOTmayn@ev1.net says...
That did it, thanks!
