L Leigh_2 Honorable Sep 14, 2015 127 0 10,680 Sep 29, 2019 #1 Is there a power extender power board for a raspberry Pi 4 Last edited: Sep 30, 2019
Solution K K kaehligj Oct 9, 2019 If you mean any accessory port (the 40 pin connector) controlled devices, you can use anything from the Pi 1/2/3 models.
O OldSurferDude Honorable May 18, 2019 180 34 10,640 Sep 29, 2019 #2 There are many remote controlled 120V switches on Amazon, some as cheap as $14. Plug your Pi into one of these. Upvote 0 Downvote
A Alabalcho Titan Jan 13, 2011 14,016 433 81,090 Oct 1, 2019 #3 To be honest, I don't understand what you're looking for, "power extender power board"... You're looking at powering up RPi over PoE? You're looking at some relay board (controlling AC relays with RPi)? Or something else... Upvote 0 Downvote
K kaehligj Prominent Mar 15, 2018 335 26 695 Oct 9, 2019 Solution #4 If you mean any accessory port (the 40 pin connector) controlled devices, you can use anything from the Pi 1/2/3 models. Upvote 0 Downvote Solution
