News Raspberry Pi UPS PCB Keeps Your Pi Project Juiced
Stop disrupting your Raspberry Pi projects with unexpected power drops using this UPS project from Sourav Gupta at Circuit Digest.
Raspberry Pi UPS PCB Keeps Your Pi Project Juiced : Read more
Unfortunately the design uses a surface mount component which is virtually impossible to solder by hand. Also not all the design files are available so it is impossible to get the PCB made and the SMT components assembled b y the PCB manufacturer. A great pity as I wanted to make one/some of these boards.
I see 1 component, some sort of QFN package with a big thermal pad. You can solder it by hand if you have hot air.
My usual workflow:
  1. I wet all the tiny pads on the PCB with PbSnCu tin. It has lower melting point than non-Pb tins and wets better. A good flux in it is a must. I use Stannol Sn63Pb36Cu1 with HS10 flux or similar tin.
  2. I make a small drop on the QFN's thermal pad on a PCB. Not too big, or it would otherwise float on it.
  3. I wet all the tiny pads on a QFN chip with tin.
  4. I wet the middle thermal pad on a QFN chip. Again, not too big, just a tiny drop.
  5. I use flux on both mating surfaces. Mine is an old rosin based one, but you may choose a newer, safer one.
  6. I heat up the board to about 100˚C with hot air.
  7. I heat the underside of that QFN chip pads (PCB).
8 I put the QFN chip in the place
9. same as 7. - until is melts, at least partially. Continue until the chip floats around, then use tweezers to push it against the board. If it goes well, it floats to the right place. Excess tin is left outside the chip on the pads (shorting them, mostly), the rest is under the board, taken away by capillary forces in the vias in the pad.
10 I wait until the tin solidifies, then wait some 10 seconds, and then use a Ag coated woven copper wire (wetted in the flux) to put over the shots. Heat it with a soldering iron, effectively melting excess tin and absorbin it into the wire.
11 I inspect it with a magnifying glass.
I have soldered some hundreds of soldered packages like this.
Hot air, good tin (0.5mm dia) with good flux and a standalone flux plus woven wire does all the tricks. I solder 0.5mm pitch chips.
Great if Tom's hardware could review the different ups boards for raspberry. There are a bunch : x708, x750, rpi ups v3, pi juice,... With different amps
