[SOLVED] Rate my build - System for 60fps 1080p gaming
Ziadul87
Respectable
Sep 7, 2019
592
62
2,240
59
https://www.newegg.ca/asus-geforce-gtx-1660-super-tuf-gtx1660s-o6g-gaming/p/N82E16814126359
Replacing your build with this GPU (Zotac version is even cheaper, second link) will still keep the build cheaper than his initial build.
Perhaps better option:
PCPartPicker Part List
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor ($189.99 @ Amazon Canada)
Motherboard: ASRock B450M PRO4 Micro ATX AM4 Motherboard ($112.09 @ Vuugo)
Memory: G.Skill Aegis 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory ($64.99 @ Newegg Canada)
Storage: Crucial P2 500 GB M.2-2280 NVME Solid State Drive ($77.99 @ PC-Canada)
Storage: Hitachi Deskstar 1 TB 3.5" 7200RPM Internal Hard Drive ($37.27 @ Amazon Canada)
Video Card: Gigabyte GeForce GTX 1660 6 GB OC Video Card ($294.99 @ Newegg Canada)
Case: Azza Titan 240 ATX Mid Tower Case ($54.99 @ Canada Computers)
Power Supply: Corsair CV 550 W 80+ Bronze Certified ATX Power Supply ($74.98 @ Amazon Canada)
Total: $907.29
Generated by PCPartPicker 2020-09-09 17:03 EDT-0400
Ziadul87
Respectable
Sep 7, 2019
592
62
2,240
59
Everything else seems fine. But i think it's better if you got yourself a Ryzen 5 3600 and a B450/B550 mobo with 3200/3600mhz CL16 RAM. It'd perform way better. [Ryzen build suggested on the message below]
Reactions: Djak372
Ziadul87
Respectable
Sep 7, 2019
592
62
2,240
59
https://www.newegg.com/g-skill-16gb-288-pin-ddr4-sdram/p/N82E16820232880
https://www.newegg.com/amd-ryzen-5-3600/p/N82E16819113569?&quicklink=true
[Note: the motherboard i mentioned is just for reference. You can get any other mother as per your wish. There may also be better performing mobo in this price range]
This build won't cost more than your initial build but will perform a lot better.
IMPORTANT: The GPU you used is a lot overpriced. Here's a GTX1660Ti for almost identical price:
https://www.newegg.com/msi-geforce-gtx-1660-ti-gtx-1660-ti-ventus-xs-6g-oc/p/N82E16814137392?&quicklink=true
Reactions: Djak372
punkncat
Ambassador
Not familiar with Canadian pricing, but would look to replace that RAM with some faster Ripjaws on both hertz and latency.
I would personally drop to a smaller NVME, bump the GPU, possibly go with a platter drive for space as a tide over...and consider a more powerful PSU based on the above selection.
Reactions: Djak372
ocer9999
Total: $907.29
Ziadul87
Respectable
Sep 7, 2019
592
62
2,240
59
Total: $907.29
