Hey guys all intel guy finally switched over to amd and have some concerns about my cpu.
Dark rock pro 4 ,kryonaut paste, crosshair viii dark hero . Voltage under load shows to be 1.5v solid across most of my cores
Im seeing between 43 and 60c at idle/web browsing and spikes up to 70c . Under prime 95 for 10 minutes I went up to 85c then started to slowly thermal throttle back to 3.5-7ghz per core.Gaming mostly stays around 84c unless I shut off my case fans(Corsair7000x). With those off I hit 92c and alt f4'd the game to go put them back to balanced mode. What concerns me is how crazy fast this thing is spiking in temps it seems like within seconds I go from mid 40s to upper 70s sometimes just moving windows around. I tried disabling pbo and that didn't see to make a difference. Are these just pretty hot chips? I lose on the lottery or what? maybe because im somehow getting near 5ghz on most of my cores without touching my overclocking settings? :monkas: I have flashed the bios to the latest and that also made no difference.
Here is a cap of my hw monitor. All I have done is open this and type up this post. View: https://imgur.com/a/VpUQGyd
Any input is extremely appreciated
Edit, with pbo off and auto overclock off my cpu sat locked at 3.4ghz and never went above 70c doing anything.. so do I leave it running on border of spicy meatball problems or just disable all the auto overclock stuff? The cpu never went over 1v when it was all off
