raw sd card solution not working help
halomaster8000
So i tried to add Simple volume
Volume size 30435 max for 32 gb
Did not format
And click finnish
Then says
Virtual Disk Manager
Data error (cyclic redundancy check)
Pleas help
Thanks
If you are getting CRC errors, it sounds like your card has gone bad. Contact the manufacturer to see if your card is under warranty and follow their RMA process. You may be able to get a replacement under warranty.
Good luck.
