Question Razer Basilisk Ultimate Wireless -- CS:GO Issue Automatic Weapons Randomly Stopping
Rodri12
35
4
535
Hi, as the title says I am having issues with this mouse and CS:GO and CS 2 Limited Test, when using automatic weapons (mainly) the gun suddenly stops shooting, this is not in exact intervals, sometimes it shoots 3 rounds, sometimes 10, sometimes all of them but this latter happens rarely, any suggestions? I've already reset all binds and reset the computer. I have also confirm this is not happening in other games I play like DOOM Eternal
Nevermind it is happening on doom as well, either wired or wireless, and I can see the problem is happening only when putting a lot of pressure on the mouse with my finger.... is this a hardware issue or software?
Sounds like hardware if pressure is affecting buttons. Your mouse uses optical switches so it's possible the pressure is interrupting the signal
But this did not happen until recently, the mouse was working just fine and then this started happening, and is not like I am pushing as hard as I can, I should have just said a little pressure I exaggerated with a lot, just the same pressure as when you are in a 1v1 and in the moment... not necessarily breaking the thing..
As suggested by a site I changed the Primary mouse button on Windows settings to the right one, tried shooting with the right side button, no issues whatsoever, looks like there might be a dust particle or something under the sensor blocking it.... will update once I get my hands on some compressed air.
Blasting it with air would not fix it, not going to bother opening it and ruining the mouse feet, going to return it and this is as far as I got in trying to fix it.//
