Question Razer BlackShark V2 Pro Wireless Gaming Headset
Feb 26, 2023
33
The sound on my headset is great, but the mic sounds really bad. It sounds worse than my headset from the dollar store. I'm not sure if there is anything that can be done to fix it, or if its just a poor quality mic. Considering this headset was $120, I was hoping it would have a decent mic. for recording.
Thanks.
You need to go into your sound settings and make sure that for ALL other devices, even if it looks like they are not "mic" related, those mic inputs are disabled. It would be really helpful to also know ALL of the specs for your other hardware including ALL add in or peripheral hardware, and what exact Windows version AND build version you are running. Motherboard BIOS version would be very helpful as well as potentially being very relevant.
Because this could be anything from poor BIOS support, to bad driver version, to multiple input feedback loop, to simply Windows not knowing WTF is going on because there are too many "enabled" microphones.
