Razer Blackwidow no clicking sound.
QRCodeKiller
27
Hi, I have a Razer Blackwidow Ultimate 2013 edition but my right arrow key is a bit different from the other keys. My right arrow key feels different, this key is pressed so easily that i can hardly feel the clicking of the Blue switches. Also it sounds different, while all the other keys have the nice crisp clicking sound the right arrow key has a very subtle click sound that i can barely hear. Also the click sounds not as clicky like its dead and flat.
Is there any ways i could fix this key?
Carefully take the key cap off (find an object that will slide underneath and use it to pry it off, using other hand/fingers if needed) and I mean very carefully as you don't want to break it.
Check if there is a blue switch there, you'll know straightaway as the switches are bright blue. If it's there then press it a few times and see what happens.
If it's still pretty easy to press and not as loud then contact whoever you bought it from and ask them to check it for you
W48Vnu
