Question Razer BlackWidow V2 after distilled water bath
May 8, 2019
6
Hi, a few days ago I spilled coke on the keyboards and read on the forum where I found out I had to wash it in distilled water. It's been 3 days, I connect to the computer and the keyboard does not work. Lights up, in the computer shows that the BlackWidow V2 is connected, only the backlight reacts, but ignores the completely pressed keys. Anyone have any ideas?
So no keys work at all?
I'd say its dead, but really to clean it, you have to remove every key, use a toothbrush and clean. Not sure why you would submerge it in water though....strange
But if nothing is working, not even 1 key, I'd say its dead.
Coke is dreadful, there is a reason why it causes cancer :)
Reactions: Kogomid
After bathing it in water, did you dry it properly, and then did you shake it to make sure the water was all out of it?
How long before you bathed it after you got coke in it?
Maybe it should be a lesson to you, don't drink that crap Coke (and other soft drinks), and drink more water :)
Mandark
1,517
166
19,990
13
You really will have to clear out each switch which would mean pulling each key and cleaning each switch carefully and making sure everything is dry just to make sure that it’s really broken
