[SOLVED] Razer Cynosa Lite problem
NEOCROM
BANNED
Feb 10, 2013
219
Got a problem with some keys, left CTRL and TAB buttons, they don't make contact fast enough, i must press the buttons harder in order to work. Even ESC button has sometimes a slight delay, but not that much of a problem.
Question is. Is there a possibility to fix this, or it's a manufacturer problem and i should send it back and get other one in return?
If it's just some buttons then it's problem with their switches. Return it.
