[SOLVED] Razer Deathhader Elite, optical red light
xyloosepwr
54
Mouse dropped and optical red light no longer work, after that mouse somehow automatically changed dpi on max, but i was able to set 400dpi again. I don't have tracking issues but i am not really sure is my mouse broken or not.
Lutfij
I usually think of Razer peripherals as overpriced plastic devices. If the mouse is yet meeting your needs then I'd suggest you not worry about the drop. If the mouses cursor is all over the place then you're better off replacing the mouse or finding a technician/electrician who is proficient with mouse sensor replacement/repairs.
Lutfij
