Question Razer Electra V2 USB Mic Problems
ChocolateKnight
7
Hello
So i've had this problem for a while now and i'm still searching for a fix.
So basically whenever i am playing games and talking to my friends via discord my mic changes suddenly, either it is a high pitched mic or a very low pitched mic.
I've searched on the entire internet and nothing seems to work.
Also installed the drivers, uninstalled and then reinstalled and still no fix.
May 28, 2020
Maybe enhancements should be enabled in sound settings > scroll down to input > under headset microphone click > device properties > additional device properties of the device, and if you don't see enhancements tab then they are enabled by default in windows, that's the first step, do that for the output also, and in synapse try turning on every enhancement for the mic. Try putting as I did, normalization on 100%, mic sensitivity on 80%, ambient noise reduction on 50%. Do you use them with desktop pc, or with a laptop? I use them with a laptop and I have a lot of problems with disconnecting. Maybe I have solved the problem today, I will see tomorrow.
