Review Razer Huntsman V3 Pro TKL Review: Watch Out, Wooting
A note to any gamer that uses function shift keys and is considering buying this keyboard, well it is normal for a Razer keyboard to have "protected" buttons that can not be bound to hypershift, on this keyboard both Tab and Capslock are protected.
In practice, the most likely key you will want to bind to hypershift is Capslock, as it usually has no function in a game. To have a usable function key you can use with only your left hand well the right is on the mouse, you need to rebind capslock to ctr, and ctr to hypershift. This is jarring to years of muscle memory, and means you have to constantly swap profiles when you want to use windows "normally."
My advice is, if you are the type that uses function shifts so you don't have to move your hand as much, get a Hunstman Gen1 keyboard, as those will let you rebind capslock.
Though if you really want the newer analog switches, you have to look elsewhere such as Wooting's keyboards that allow total remapping.
