Razer Kraken Pro Sound&Mic Too Low.
Seigin1Craft
Hi guys i just wanted to know that why my razer kraken pro audio sound very low.. I have uninstalled Razer surround too help me! Its serious? Btw when tried the headset after opening the sound all good but after downloading razer surround it got the headset volume too low.. And i think the mic is not working too 🙁
Hello all,
Here is how I fixed it. It is kind of a tedious process but, it worked for me.
1. Open device manager and uninstall the Razer Kraken headset driver in the sound sub-folder.
2. Unplug your headset.
3. Delete the Razer folder in C:// Program files folder (may be labeled Program files x86).
*If you cant delete it then you have a process running in the background.
*Open up task manager and look at your processes. Close any Razer processes.
*One particular process seems to return within seconds so make sure when you end the process, have your folder up to delete.
4. Once you have the folder deleted, restart your computer and plug back in your headphones.
If this doesn't help you or you have trouble with it let me know.
Thank you!!!!!!! 😀😀😀😀
i have mac so help me
wow thanks so much!
Last thing you can also check is the volume control attached to the green cable. In addition to the remote, you have another control system on the cable itself.
