Razer Mouse double clicking problem?
Dylan1999
698
I have a razer deathadder 2014 thats been good for a while but lately, at random, its been clicking by itself twice, when I would only click it once. Like its not an actual physical double click, I think theres something wrong with the mouse internally or with razer synapse or something. I just updated synapse and that didnt fix the problem. It seems to have fixed one problem i was having where when I was playing a game, the left mouse click button stopped working. Any suggested would be great!
its a know problem with all of Razers mice. It happens on mine too at random times. As far I know the only true solution is don't buy a Razer mouse.
From everyone's wild attempts at a fix it seems clear the problem is somehow software based. As people seem to be able to fix it, for a while at least, by install or uninstall the synapse software. How are why this would change anything I don't know.
ill try reinstalling synapse then. thanks!
should I maybe get a corsair gaming mouse?
Logitech Mice do this as well. There's a trick to try and fix it:
The toggle switch that operates the 'button' sometimes gets a static charge buildup. To help release it, breath a few breaths into the gap between the button and the base of the mouse (the slit that allows the button to move and 'click'). The humidity in your breath will usually dissipate the static buildup and the button will stop double clicking- most of the time. I repaired a Logitech G602 using this method, it might work on the Razer mice as well.
*Note- it may take a few tries to do this, I had to do this to my mouse over several days. Slow breaths are better as it allows more humidity to dissipate the static.
I dont really have a budget, but I dont exactly wanna spend $500 on a mouse either 😀
