Razer Mouse Problem
meshbinff
8
Hello i got a problem with my deathadder mouse i got it 2 years ago or something
it is good but now it goes off every 1 min or something like this when i game but it doesn't when i'm browsing i tried to update the driver and it keeps doin this i tried to un plug it and re plug it same change the port and same and after changing the port my hyperx cloud 2 had the same problem it keep going off but not too much like the mouse
PLZZ HELP 🙁
You have the headset in the same port as your mouse was and now that is disconnecting also? Could be an issue with your USB ports, although if your mouse is bad it could be causing issues with other USB devices. Try another mouse, see if that works better.
