News Razer's $130 Aether monitor light bar is — shocker — infused with Chroma RGB
For about $20 you can have a smart light strip you can wrap around and behind your monitor that you can control with your phone and not Razer's horrid Synapse software suite and is USB powered for no wires visible (if your monitor has a USB hub).
In related news, Razer synapse still requires over 400 MB of memory split between a dozen apps/services to control their RGB lights.
And it forgets my settings every time I reset my PC
Be glad you only have to have one version. I have the "older" Razer BlackWidow X Ultimate which doesn't support the new Synapse so I have to use the 2.21 version as well as the newer Synapse 3 for my Razer Naga X.
Reactions: Giroro
