Question RBG Lights on Saberay White case
Dec 23, 2018
17
Just got the Saberay White case from Enermax. The RGB stripes on the outside of the case and the case fans RGB aren't turning on. The case fans are on but no RGB. I've looked all over for a solution.
Reactions: SirTetra99
I assume that you transferred an existing build to the new case or? If yes, are you using the hub that comes with the case or did you connect the rgbs to the mobo? If the latter, what model is your mobo?
Yooo i got the same prob too! it starts up, the fans and everything else will boot up as normal but the RGB's on the case will just flash once and stay off. not sure whats going on damit. xD help
