Archived from groups: microsoft.public.windowsxp.work_remotely (
More info?)
Hi Shenan,
What I was trying to say is that I would to connect from the W2k machine to
the XP Pro machine, but thank You for your response that I cannot connect
from the W2k machine .
I will try Netmeeting and see if I will be successful.
Thank You Very much for your help.
Joe
"Shenan Stanley" wrote:
> JoeD wrote:
> > I have a pc running W2k Pro that I would like to connect using the
> > RDC to connect to another machine that is running XP Pro.
> > I am able to connect from the XP Pro machine but unable to connect
> > from the W2k Pro machine. All help will be much appreciated.
> I am confused by your statements.. First you seem to infer there is a
> Windows 2000 Professional machine you would like to use as a client to
> connect to a Windows XP machine. Doable - install the RD client on the
> Windows 2000 Professional machine and do it.
> Then you state that you are able to connect from said Windows XP
> Professional machine - to what? You've only mentioned two machines - do you
> mean the Windows 2000 Professional machine? If so, then what method are you
> using to remote? Some flavor of VNC? Perhaps Netmeeting? Windows 2000
> Professional does not have a terminal services license.
> In any case, you go on to state that you are able to connect FROM the
> Windows 2000 Professional machine to the Windows XP Professional machine -
> okay - yeah - we established that is possible. What do you need help with?
> Windows XP Professional has a Remote Desktop service.
> Windows 2000 Professional does not.
> You need to install a third party application like UltraVNC in order to
> remotely control Windows 2000 Professional from ANY other type of machine or
> use Netmeeting.
> <- Shenan ->
> The information is provided "as is", it is suggested you research for
> yourself before you take any advice - you are the one ultimately
> responsible for your actions/problems/solutions. Know what you are
> getting into before you jump in with both feet.
