I have two PCs and would like to access both of them externally.
I have two routers:
1. is MODEM-ROUTER
2. a regular ROUTER
There is a connection between the LAN connection of the first goes to the INTERNET connection of the 2nd.
The first PC is connected to the MODEM-ROUTER and is using the default RDP port (3389), did the port-forwarding and all works well.
The 2nd PC is connected to the 2nd router, I configured the RDP port to be 3391, disabled firewall and I manage to connect internally, but not externally.
I configured a VIRTUAL SERVER properly to forward incoming TCP connections to port 3391 to that PC with port 3391. It still doesn't work. I am thinking that perhaps its related to the 1st MODEM-ROUTER being on the way? Should I do something there?
I have two routers:
1. is MODEM-ROUTER
2. a regular ROUTER
