Re-using Raid 0 SSDs...
c3berns
I had two Raid 0 SSDs set up on another rig which has since bit the dust. I just wanted to format them and use them in a non-Raid setup, but can't see them on a different computer.
Can't see them when I put computer in raid, can't see them in device manager, etc.
Do I need to completely reformat them, as if I were loading Windows on them for the first time? Or is there another way I can do it from Windows...
You should be able to see them in the new computer if you reboot and go into the RAID controller. It might see them as a RAID member and you may have to delete the RAID config. Or do you not see it at all in the RAID controller when you boot? If not, does the BIOS or UEFI recognize it?
