Ready to Buy Parts - Review please
oldboomer
17
I've done the research and gotten some help here. Now I'm ready to go.
This system will be used for Photoshop – editing larger images (now 20 Mb each). Other apps are standard business stuff. No games. No overclocking. Quiet operation is a big deal for me - it is a quiet area now! Reusable parts: 2 monitors, SATA drives, SATA DVD, and KB, mouse, etc. This is my to-buy list.
Cooler Master CM 690 II Advanced CASE
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119216
Antec EarthWatts Green EA-430D PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371034
Intel core i5-2400 CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115074
ASUS P8Z68-V LX motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131781
Corsair Dominator 2x4GB, DDR3 1600
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145345
The total comes to about $500 - I'm OK with that.
So, what do you think? Add, delete, substitute... Thanks for your feedback.
And I hope you will all be as helpful when I start the build
:wahoo:
What you need is 100% for sure a MacMini. Its tottally silent, and its compatible with the magic mouse, a touch sensitive mouse that lets you scroll horizontally.diagonally etc...360 degrees, thats ta must for working with picutres.
If you dont feel confident getting a Mac, there is a equivalent on windows side:
http://www.amazon.com/Microsoft-3KJ-00001-Touch-Mouse/dp/B004HYGU18/ref=amb_link_357150482_2?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=right-csm-1&pf_rd_r=1HZ761FWKZQ4PKTFGZZ1&pf_rd_t=101&pf_rd_p=1317432382&pf_rd_i=507846
and check www.silenx.com for the fans
