B blohm85 Reputable May 16, 2014 70 0 4,640 May 19, 2014 #1 these are my specs 2 radeon 7850s in crossfire amd a10 5800k 1 wd blue 1 tb atx gigabyte fm2 board 2 blu ray drive thank you much everyone for your help
Solution badboyrog2 May 19, 2014 you need a 430W minimum , so i add always 200W to be safe so a 620W psu should be ok
badboyrog2 Distinguished Mar 5, 2014 6,953 0 18,960 May 19, 2014 Solution #2 you need a 430W minimum , so i add always 200W to be safe so a 620W psu should be ok Upvote 0 Downvote Solution
justcallmetom13 Reputable Mar 17, 2014 385 0 4,960 May 19, 2014 #3 I would go with either a very high quality 650W PSU or a mediocre quality 750W if you want some headroom. Upvote 2 Downvote
hans_pcguy Distinguished Nov 13, 2010 584 1 19,265 May 19, 2014 #4 Your rig is a power hog. I wouldn't go with less than a good 620 Watt. Upvote 1 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 May 19, 2014 #5 You need about 550w due to the Crossfire of the 7850's Upvote 1 Downvote
