Ok. I have read through the forums and I am just trying to get an opinion.
Core i7 920 D0 Stepping
OC'd to 3.5ghz
HT is ON
Turbo Mode is ON
VCORE 1.25v
6GB Kingston 1333mhz (10666)
Ration 2:8
DRAM Voltage 1.5v
BCLK 170
ASETEK Low Cost Liquid Cooling
NZXT Zero 2 Case
2x Apevia 120mm side case fans
2x Enemex 120mm fans insdie - radiator over 1
PSU blocks top seat fan and radiator blocks 2/4 side case fans from installation
I have high idle temps of the high 30's and low 40's WITHOUT the OC. While gaming in the 50's
WIth the OC the idle temps are in the mid 50's and low 60's while gaming
I ran PRIME95 and it's stable but the temps go up to the high 80's.
What could possibly be wrong?
Thank You!
OC'd to 3.5ghz
HT is ON
Turbo Mode is ON
VCORE 1.25v
Ration 2:8
DRAM Voltage 1.5v
BCLK 170
NZXT Zero 2 Case
Thank You!
