really need help!!!
edmon1
15
hey
i'v changed my primary graphics adaptor in bios to external mode accidently !!
now nothing boot just black screen on my laptop screen fan work good but nothing to show!
my laptop is lenovo ideapad 500 with in-built battery so i cant remove my batery !
plz help me to rest my bios or another easy way!!
tnx for replay bro
but it didnt work cuz i set priamry graphic adaptor on external so my laptop didnt show anything!!
i need to reset my bios with some way tht i dont know 🙁
then should i put it back and turn on the laptop with AC ?
if this didnt help me wht should i do bro? 🙁
And should i unplug the wire of battery from mainboard same as CMOS battery??
"And should i unplug the wire of battery from mainboard same as CMOS battery?"
You can unplug the main battery? You should have said so earlier.
Yes, that's a good idea. Unplug AC adapter, Unplug main battery & remove CMOS battery.
Wait at least five minutes before reconnecting main battery & putting CMOS battery back.
my battery is in-built bro !
but tnx i will try this solution tnx
sorry
If pressing the "novo" button on the side of the laptop doesn't get you into the bios, then you can try pressing FN + F2 after switching it on. The FN(function) key needs to be pressed to utilise the F keys.....I know because this has caught me out in the past.
You should be able to get into the bios and change back the graphics setting or reset the bios to default. No real need to pull the CMOS battery.
UPDATE - If you have a monitor or TV available...you could plug in an HDMI cable and get the display external in order to change settings back also.
nothing happend bro 🙁
now i try to Pickup the CMOS battery for 5 min and try again...
anyother idea?🙁
i tried this solution with no success:
picked up CMOS battery for 5 min and turn laptop nothing happend!
nova button doesnt work !
anyone know any idea??
So when you first switch the laptop on......are you getting any display before it starts to load Windows? It should at least be showing you a post screen to allow you to access bios.
Did you try plugging in an external display yet?
no i just see an black. screen no loadding windows!
and after i change primary graphic adaptor to external in bios this shit happen to me!:|
I think you might have a deeper issue then. Check HERE and see how you go.
