First the question;
Which temperature should I pay attention to; core temps or cpu temp?
This is a very important question in my case as I seem to have inverted cpu vs. core temps. Without any overclocking and a Vcore of 1.23 my cpu temps at idle are 40C with core temps in the low 20's. At 100% Load (TAT), cpu temps get to 70C but core temps are reasonable at around 47C. Using Core temp, it reports I still have 37-40C to Tjunction, so if the core temps are the primary ones to worry about then I should be fine but, if the cpu temp is the issue then I seem to have a problem.
I have made a couple of posts in this forum and no one seems to be able to explain why the cpu temp is higher than the core, but if anyone has an answer for this I would also like to understand this as well.
I have read great reports of this processor and overclocking but really need to understand what is going on before I start generating any more heat.
All replies are greatly appreciated!!
System info;
MSI P35 Platinum board (bios v1.2)
E6850 (running at stock speed)
Zalman 9500 cpu hsf
Thermaltake Toughpower 700W psu
Mushkin eXtreme Performance 2GB (2 x 1GB) (PC2 6400) - (running at 1:1, so operating at 667MHz)
System info;
Zalman 9500 cpu hsf
