Hello, just a few hours ago, I seem to have experienced a problem with my Realtek Audio Drivers with it sounding bad. I usually fix this by just going to Device Manager and "re-updating" it to Realtek HD and fixes it.
However, today it seems that doesn't seem to be working. Usually, when I do the update, the speakers turn off and it prompts me to restart, and after restarting the speakers re-enable.
However, this time - when I update, the speakers disable and a second after the prompt appears - my speakers immediately re-enable again.
My Realtek Folder seems to be missing as well (not on Program Files, there's a few Realtek Folders scattered around but it doesn't contain the same files as the one that's supposed to be on Program Files).
Does anyone know a fix for this? According to the Console, I'm using Realtek Version 6.0.1.8639 and I'm using an ASUS Laptop with a FX505 Model.
I tried reinstalling the drivers but doing so makes it incompatible for Realtek Audio Console which is something I kind of need for its enhancements.
