Hello. I recently grabbed a custom built PC and I've been having slight audio crackle issues with it. I'm almost 100% sure that it has to do with the realtek soundcard, but maybe someone else has another idea.
There are certain frequencies that seem to cause my audio to crackle, usually on the bassier end of the spectrum. I've tested it across two different devices. My main computer, which is a desktop, and my laptop. Both have realtek soundcards and I can get both to reproduce the same crackling from certain test audios with both speakers and differing headphones.
I've tried a bunch of different steps to try to fix it. I've tried setting my minimum processor state to 100, I've tried uninstalling the realtek audio driver and installing the base HD ones by windows, I even ordered a usb soundcard and tried operating through that. Nothing seems to help. All those suggestions that you can find with 5 seconds of googling that seem to be the only suggestions didn't work, so now I'm looking for windows 10 compatible realtek drivers. I've tried the ones that windows automatically installs, and even the ones from my motherboard's website. Any suggestions?
Just for reference, my motherboard is an Asus PRIME Z370-P. I've heard there are some audio issues with the asus prime line, but I haven't found a fix for that, either. Barring that, my laptop has a non asus motherboard, so I'm unsure if that's the issue here anyway. Sorry if this is in the wrong board.
