realtek audio manager setings for 2.1 speakers
valleron2010
153
if i choose stereo mode im getting too much bass from logitech 2.1 speakers and they dont have bas control.what are the best settings for average bass and clear audio?
It is going to be a balance to get what you want, just slowly drop the 31-250hz(30 hz may not do anything with that system, but 60 and up should be noticeable) range until you get what you want.
its Logitech Z313 and they not have a bass control on the subwoofer.can you show me the best equalizer settings to have bass but not too much?
ok i will.thanks
can i choose 5.1 preset?because there is an option for bass management
Setting 5.1 would cause some issues if you had a 5.1 audio source play.
It is common for 5.1 setups to have voices on the center channel so setting 5.1 on a 2 channel system can cause those types of issues.
Some programs also have build in equalizers you can adjust.
Very small adjustments to the equalizers can make a noticeable difference.
