I've searched the forum for similar cases that might have been solved already, but alas, I couldn't find one, nor through using Google (or maybe my search was just too generic).
So here's my problem:
My Motherboard is an Asrock Extreme 9 990FX, and I'm using the inboard sound chip that does not work at all.
My front panel audio jack does not work, nor my rear panel audio jack. When I plug-in a speaker or an headset, all I could hear is crackling/static noise. I've installed the latest drivers from Asrock's website, and yet there's no sound output aside from that static noise.
The driver that I installed is:
Realtek high definition audio driver ver:6788
Is there something that I should look onto to get this to work? Or is this an hardware issue, and I should just fetch myself a dedicated sound card?
Any help or info would be greatly appreciated. And hopefully I could save a couple of bucks by not buying a sound card.
By the way, I already looked into this topic: http://www.tomshardware.com/forum/301785-30-realtek-audio-installed-sound
The solution posted there did not help at all on my case.
