Realtek HD Audio Manager Bit/Hz settings.
pd2cwe
24
I unplugged my headphones earlier today to use my monitor speakers for the first time, and when I plugged my headphones back in I had to apply a setting in Realtek HD Audio Manager. The default setting was 24 Bit 48000 Hz but there were quite a few options, with one going all the way to 24 Bit 192000 Hz.
I'm not sure how these work and I've heard that changing these could possibly ruin my headphones so I don't want to mess with them without knowing what it's going to do first.
that refers to the quality of the audio processing. generally i keep it on 24b/192khz
this is not volume output so there is no way it will damage headphones.
think about it like playing either very bad quality mp3s vs playing a high quality aac or flac file. you can hear the difference in quality despite your volume level being the same.
now, will you notice between 48khz and 192khz? depends on your ears.
But to answer your question directly, changing this setting will have absolutely no negative effects on your headphones. If you turn it all the way down to say 16 bit 44.1 khz, this will not effect anything really. If you have a really good stereo hooked up to your computer, you might notice a subtle difference, but not much.
