Realtek HD Audio Manager changes settings by itself
Fyrexx
Hello, about a week ago my realtek audio manager started literally changing settings by itself when I haven't touched the mice or keyboard for about 10 minutes or so. I tried reinstalling the driver, didn't help a bit. It's quite annoying since i have to change it back to the settings I need every time it does that. It was working just fine before that. I've got no idea at all what could have caused this whatsoever.
Try a complete uninstall, then use driver fusion to remove any left over files, then proceed to reinstall the drivers.
driver fusion can be downloaded from here:
http://treexy.com/products/driver-fusion
Super simple program to use, just select the driver from the list to be removed, in your case 'realtek sound' drivers, press analyze then delete.
Ive had the problem you described in the past with a creative sound card, using drive fusion fixed the problem.
