Realtek HD Audio problem
bigglesworth1
48
Greetings everybody
I recently installed my GIGABYTE GA-MA69GM-S2H, everything works fine except the Realtek HD Audio. I'm not sure if this is caused by my Sound Blaster Audigy SE, which I use as my primary sound device. I only want to use the Realtek Audio with my headphones. Thanks for the help.
mr. bigglesworth
a little more info as to what kind of problem.. ie, drivers not loading, drivers loaded but no sound, stuff like that.
also if you have front panel connections hooked up,
Sorry that I forgot to mention that the Realtek HD Sound does not work at all. Everything is enabled, and everything is hooked up to the front panel. When I switch from my Audigy soundcard to the Realtek HD Audio output on the little volume icon on the task tray and plug in my headphones, I still can't hear anything. I wonder what the problem is...
Try the drivers from the RealTech website. That being said, generally better not two run audio cards, could take the Creative out and see if the Realtech works
I used two sound devices without any trouble at all before I installed my GA-MA69GM-S2H. My old mobo was the ASUS A8AE-LE and I frequently switched between my Audigy and Realtek AC'97; it worked great. I just don't know what the problem is now 🙁
I think IRQ is your problem . If it is 22 , 24 , particulary high , Realtek Sound device isn't work . Try to change IRQ [5 or 7 or 9] for sound driver, or try to install a new Windows XP [install with "format c:/" NTFAT] , and when your windows is new one , install first your driver sound. I have me too similar problem in the past , and I solve it so. I glade if your probleme was solved through this.
