Realtek High Definition Audio (No Sound through Laptop Speakers)
thjoseph
5
I will try to be as detailed as possible. I am pretty experienced with drivers and sound settings but this problem has me stumped.
I have a Fangbook III made by Cyperpower PC. I am unable to play sound via the on-board speakers for the laptop. I am however able to play sound through the 3.5mm auxiliary jack input. I have speakers set as default device under the playback settings.
This is where is gets strange. Whenever I attempt to delete the Realtek audio driver, whether it is through windows or a 3rd-party driver uninstallation software, Realtek always comes back within a few seconds. Right before it does come back, under playback, it separates speakers and headphones with both having the driver High Definition Audio Device. If I hurry before the Realtek driver comes back the speakers seems to work! But once the Realtek audio speakers comes back, the default speakers and headphones goes away and I continue to have the same problem with the Realtek driver.
I attempted to reformat the computer with windows 10 and erase all drivers but Realtek was already installed. I assume it is required for this specific laptop? Any ideas on how to direct the Reaktek High Definition Audio driver to use the speakers instead of the auxiliary jack?
Thanks for the help and let me know if there is any more information that you guys need.
http://i.gyazo.com/34cb4f30b73b8227fbe004549ed15e9f.png
http://i.gyazo.com/05b38de1c8fc1fc0e03aab5f23d52b9b.png
You can prevent Windows from automatically installing drivers for you. Navigate to Advanced System Settings via Search in the Start Menu. Go to the Hardware tab. Select "Device Installation Settings." Click "No, let me..." then select "Never install driver..." Press Save Changes. Press "OK."
Windows 10's particularly aggressive driver installation procedures can be painful at times.
