Realtek PCIe GBE family controller wireless adapter
Deshan
16
after updating driver software wifi adapter automatically disabled then i have to re enable it. enabling last about 2 minutes! i have rollback the driver software then it works correctly.how to use newest drivers without issues!
windows 10 64 bit
ASUS X555L
This is a very common problem in Windows 10. Microsoft recommends resinstalling the driver and running the Network Troubleshooter. There is also a Fixit available that sometimes help:
https://support.microsoft.com/en-us/kb/299357
I would also go in to CP>Power Options>Power Plan>Change advanced options and set the the wireless adapter to maximum performance. One last thing is to go to Device Manager>Network Adapters>right click your adapter and select Properties. Under Power Management, uncheck the box allowing the OS to turn off this device to save power.
