Question Realtek RTL8811au Wireless LAN USB Driver error
Jun 11, 2019
6
Everything was working fine until today, i tried to get on the internet on my PC running Windows 10, and my network adapter no longer is working. When I select to update the drivers which i’m sure will fix it, i get an error that says, “Windows encountered a problem installing the drivers for your device” then below that it says, “Windows found drivers for your device but encountered an error while attempting to install them.” Any help would be awesome since my PC is basically unusable at this point!
Hello cincy,
Could you provide us with more information? In particular it would help to know the model of your network adapter that you say is not functioning.
Also have you tried to install the drivers for your network adapter manually from the manufacturer's website, or are you relying on Windows Update to find them for you?
