Question REALTEK RTS5186 card reader does not work
Matthew Wai
127
I have a card reader with a 9-pin USB header, which fits a USB connector on my GA-H81M-DS2 motherboard, which uses H81 chipset. The reader was removed from and had been worked fine with Lenovo Edge 71, which used H61 chipset . However, it does not work with GA-H81M-DS2, whose boot menu shows no SD card, which will be shown if it is in a reader with a USB-A connector.
The problematic reader uses REALTEK RTS5186. Is it possible for H81 chipset not to support RTS5186?
The 9-pin USB connector on GA-H81M-DS2 works with my USB HDD and flash drives, so the problem does not lie in the connector.
Thread starter Similar threads Forum Replies Date
J Components 1
ElementCZ Components 6
