Mohamed_45 Honorable Feb 10, 2016 84 0 10,640 Oct 6, 2016 #1 I cant install my Audio drivers after trying to update the driver ? I don't know the reason or the cause of the issue ?
Solution T T TheUploader Oct 6, 2016 Maybe its already installed and bugged. Can you uninstall the driver? Try doing that and then manual download the driver online and install it.
T TheUploader Commendable Oct 3, 2016 78 0 1,660 Oct 6, 2016 Solution #2 Maybe its already installed and bugged. Can you uninstall the driver? Try doing that and then manual download the driver online and install it. Upvote 0 Downvote Solution
Mohamed_45 Honorable Feb 10, 2016 84 0 10,640 Oct 6, 2016 #3 I have tried uninstalling the driver and reinstalling again and it didn't work ? Upvote 0 Downvote
Mohamed_45 Honorable Feb 10, 2016 84 0 10,640 Oct 6, 2016 #4 I reset my windows 10 and everything returned to normal and I successfully updated my audio drivers Upvote 0 Downvote
T TheUploader Commendable Oct 3, 2016 78 0 1,660 Oct 6, 2016 #5 Mohamed_45 : I reset my windows 10 and everything returned to normal and I successfully updated my audio drivers Good to hear 😀 Upvote 0 Downvote
