My case is Fractal Design ARC MIDI R2. I have two fans in the front that serve as intakes and one exhaust fan at the back (rear), I also have another exhaust fan at the rear top.
When the pc is at idle all working fine, I can put my hand at the back of the pc and feel strong air pressure coming out of the rear fan, but when I game and the graphics card and cpu's fans (NH-D14) are working than the air pressure coming from the back is really low, I can barely feel the air coming out.
Should I remove the rear top fan and leave only the one at the back? Do you think I have some sort of resistance beteween the two fans and the exhuation is not as optimal as it should be?
My CPU cooler is directed to the back of the pc, I use noctua's NH-D14 which has two fans.
Do you thing the rear top fan is uselss?
Thanks in advance.
Thanks in advance.
