Rear fan constantly slowing down/speeding up
notsoholy
12
Hello all,
first of all here is the hardware I am using
Case: RAIDMAX SMILODON ATX-612WB
Mobo: ASUS M4A79XTD EVO
CPU: Phenom II X4 955 Black
Windows XP SP3
The problem I have is the fan in the rear of the case is LOUD and it is constantly slowing down, then speeding up and it just keeps cycling over and over. Been happening for about a week now.
I have tried using AMD Overdrive and SpeedFan to adjust fan settings but nothing has worked as of yet.
My voltage is set to 1.4v
I have enabled ASUS Cool n Quiet in BIOS
I never really figured out how to configure speedfan. My motherboard doesn't have a guide on their site. If anyone has any suggestions to help I would greatly appreciate it.
If more technical information is needed just let me know I can provide it.
I tried OCing my system a long time ago.. that's why I tried going into AMD Overdrive to see if something was oc'ed too much. I'm pretty sure I have set everything back to their default values though so I don't think anything is overclocked anymore.
However everytime I open Overdrive it has my fans set to Manual and 100%. No matter how many times I choose Automatic and hit save, they still say Manual when I reopen the program. Not sure if that has anything to do with it though. Hope they aren't being overworked for nothing.
The weird part is it happens in the middle of the night too when I don't have any programs open and the computer is actually in screensaver mode so why would the fan be struggling?
Here is a HWMonitor log:
Code:
CPUID HWMonitor Report
Binaries
HWMonitor version	1.2.1.0
Monitoring
Mainboard Model		M4A79XTD EVO (0x0000032C - 0x56D905E0)
LPCIO
LPCIO Vendor		ITE
LPCIO Model		IT8720
LPCIO Vendor ID		0x90
LPCIO Chip ID		0x8720
LPCIO Revision ID	0x2
Config Mode I/O address	0x2E
Config Mode LDN		0x4
Config Mode registers
		00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
	00	00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
	10	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	20	87 20 02 00 00 04 0C 00 C0 00 00 00 9F 00 00 00
	30	01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	40	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	50	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	60	02 90 02 30 00 00 00 00 00 00 00 00 00 00 00 00
	70	00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Register space		LPC, base address = 0x0290
Hardware Monitors
Hardware monitor	ITE IT87
	Voltage 1	1.63 Volts [0x66] (VIN1)
	Voltage 3	5.05 Volts [0xBC] (+5V)
	Voltage 8	3.41 Volts [0xD5] (VBAT)
	Temperature 0	37°C (98°F) [0x25] (TMPIN0)
	Temperature 1	31°C (87°F) [0x1F] (TMPIN1)
	Fan 0		3230 RPM [0xD1] (FANIN0)
	Fan PWM 0	99 pc [0x7F] (FANPWM0)
	Fan PWM 1	99 pc [0x7F] (FANPWM1)
	Fan PWM 2	99 pc [0x7F] (FANPWM2)
	00	19 00 FF 03 00 00 00 00 00 80 58 0F 07 D2 FF FF
	10	FF FF FF 77 D7 7F 7F 7F 00 FF FF FF FF FF FF FF
	20	00 66 22 BC FF FF FF FF D5 25 1F 80 80 17 FF FF
	30	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	40	FF FF FF FF FF FF 5F 74 2D 40 95 00 FF FF FF FF
	50	08 18 7F 7F 7F 50 56 56 90 56 06 12 E0 00 00 00
	60	7F 7F 7F 00 00 7F FF FF 7F 7F 7F 00 00 7F FF FF
	70	7F 7F 7F 00 00 7F FF FF FF FF FF FF FF FF FF FF
	80	00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00
	90	FF 00 00 00 FF 00 00 00 FF FF FF FF FF FF FF FF
	A0	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	B0	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	C0	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	D0	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	E0	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	F0	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor	AMD SB6xx/7xx
	Voltage 0	0.98 Volts [0x14F] (CPU VCore)
	Voltage 1	3.44 Volts [0x26F] (CPU IO)
	Voltage 2	12.17 Volts [0x268] (+12V)
Hardware monitor	NVIDIA NVAPI
	Voltage 0	0.95 Volts [0x3B5] (VIN0)
	Temperature 0	54°C (129°F) [0x36] (TMPIN0)
	Fan PWM 0	35 pc [0x23] (FANPWMIN0)
Processors
Number of processors		1
Number of threads		4
APICs
Processor 0
	-- Core 0
		-- Thread 0	0
	-- Core 1
		-- Thread 0	1
	-- Core 2
		-- Thread 0	2
	-- Core 3
		-- Thread 0	3
Timers
	ACPI timer		3.580 MHz
	HPET timer		14.318 MHz
	Perf timer		3.580 MHz
	Sys timer		1.000 KHz
Processors Information
Processor 1			ID = 0
	Number of cores		4 (max 4)
	Number of threads	4 (max 4)
	Name			AMD Phenom II X4 955
	Codename		Deneb
	Specification		AMD Phenom(tm) II X4 955 Processor
	Package 		Socket AM3 (938)
	CPUID			F.4.3
	Extended CPUID		10.4
	Brand ID		13
	Core Stepping		RB-C3
	Technology		45 nm
	TDP Limit		125 Watts
	Core Speed		800.1 MHz
	Multiplier x FSB	4.0 x 200.0 MHz
	HT Link speed		2000.2 MHz
	Stock frequency		3200 MHz
	Instructions sets	MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V
	L1 Data cache		4 x 64 KBytes, 2-way set associative, 64-byte line size
	L1 Instruction cache	4 x 64 KBytes, 2-way set associative, 64-byte line size
	L2 cache		4 x 512 KBytes, 16-way set associative, 64-byte line size
	L3 cache		6 MBytes, 48-way set associative, 64-byte line size
	FID/VID Control		yes
	Min FID			4.0x
	# of P-States		4
	P-State			FID 0x10 - VID 0x0C - IDD 21 (16.00x - 1.400 V)
	P-State			FID 0x9 - VID 0x18 - IDD 15 (12.50x - 1.250 V)
	P-State			FID 0x5 - VID 0x20 - IDD 11 (10.50x - 1.150 V)
	P-State			FID 0x100 - VID 0x2E - IDD 5 (4.00x - 0.975 V)
	Package Type		0x1
	Model			55
	String 1		0x3
	String 2		0x6
	Page			0x0
	CmpCap			4
	ApicIdCoreSize		4
	TDC Limit		84 Amps
	Boosted P-States	0
	Max non-turbo ratio	16.00x
	Max turbo ratio		16.00x
	Core Performance Boost	no
	P-State			0, FID 0x100 - VID 0x2E (4.00x - 0.975 V)
	Attached device		PCI device at bus 0, device 24, function 0
	Attached device		PCI device at bus 0, device 24, function 1
	Attached device		PCI device at bus 0, device 24, function 2
	Attached device		PCI device at bus 0, device 24, function 3
	Attached device		PCI device at bus 0, device 24, function 4
	TSC			3199.9 MHz
	PERFEVT			800.0 MHz
Thread dumps
CPU Thread 0
	APIC ID			0
	Topology		Processor ID 0, Core ID 0, Thread ID 0
	Type			02004009h
	Max CPUID level		00000005h
	Max CPUID ext. level	8000001Bh
	Cache descriptor	Level 1, I, 64 KB, 1 thread(s)
	Cache descriptor	Level 1, D, 64 KB, 1 thread(s)
	Cache descriptor	Level 2, U, 512 KB, 1 thread(s)
	Cache descriptor	Level 3, U, 6 MB, 4 thread(s)
	CPUID
	0x00000000		0x00000005	0x68747541	0x444D4163	0x69746E65
	0x00000001		0x00100F43	0x00040800	0x00802009	0x178BFBFF
	0x00000002		0x00000000	0x00000000	0x00000000	0x00000000
	0x00000003		0x00000000	0x00000000	0x00000000	0x00000000
	0x00000004		0x00000000	0x00000000	0x00000000	0x00000000
	0x00000005		0x00000040	0x00000040	0x00000003	0x00000000
	0x80000000		0x8000001B	0x68747541	0x444D4163	0x69746E65
	0x80000001		0x00100F43	0x10001B76	0x000037FF	0xEFD3FBFF
	0x80000002		0x20444D41	0x6E656850	0x74286D6F	0x4920296D
	0x80000003		0x34582049	0x35353920	0x6F725020	0x73736563
	0x80000004		0x0000726F	0x00000000	0x00000000	0x00000000
	0x80000005		0xFF30FF10	0xFF30FF20	0x40020140	0x40020140
	0x80000006		0x20800000	0x42004200	0x02008140	0x0030B140
	0x80000007		0x00000000	0x00000000	0x00000000	0x000001F9
	0x80000008		0x00003030	0x00000000	0x00002003	0x00000000
	0x80000009		0x00000000	0x00000000	0x00000000	0x00000000
	0x8000000A		0x00000001	0x00000040	0x00000000	0x0000000F
	0x8000000B		0x00000000	0x00000000	0x00000000	0x00000000
	0x8000000C		0x00000000	0x00000000	0x00000000	0x00000000
	0x8000000D		0x00000000	0x00000000	0x00000000	0x00000000
	0x8000000E		0x00000000	0x00000000	0x00000000	0x00000000
	0x8000000F		0x00000000	0x00000000	0x00000000	0x00000000
	0x80000010		0x00000000	0x00000000	0x00000000	0x00000000
	0x80000011		0x00000000	0x00000000	0x00000000	0x00000000
	0x80000012		0x00000000	0x00000000	0x00000000	0x00000000
	0x80000013		0x00000000	0x00000000	0x00000000	0x00000000
	0x80000014		0x00000000	0x00000000	0x00000000	0x00000000
	0x80000015		0x00000000	0x00000000	0x00000000	0x00000000
	0x80000016		0x00000000	0x00000000	0x00000000	0x00000000
	0x80000017		0x00000000	0x00000000	0x00000000	0x00000000
	0x80000018		0x00000000	0x00000000	0x00000000	0x00000000
	0x80000019		0xF0300000	0x60100000	0x00000000	0x00000000
	0x8000001A		0x00000003	0x00000000	0x00000000	0x00000000
	0x8000001B		0x0000001F	0x00000000	0x00000000	0x00000000
	MSR 0x0000001B		0x00000000	0xFEE00900
	MSR 0xC0010114		0x00000000	0x00000018
	MSR 0xC0010061		0x00000000	0x00000030
	MSR 0xC0010062		0x00000000	0x00000003
	MSR 0xC0010063		0x00000000	0x00000003
	MSR 0xC0010064		0x800001D1	0x48001810
	MSR 0xC0010065		0x80000194	0x48003009
	MSR 0xC0010066		0x8000016D	0x48004005
	MSR 0xC0010067		0x80000130	0x48005C40
	MSR 0xC0010068		0x00000130	0x48005C40
	MSR 0xC0010071		0x00800000	0x48034040
	MSR 0xC0010015		0x00000000	0x01000010
	MSR 0xC001001F		0x40584000	0x00000008
	MSR 0xC0010058		0x00000000	0xE0000021
	MSR 0xC0010071		0x00800000	0x48035C40
	MSR 0xC0010070		0x00000000	0x48035C40
CPU Thread 1
	APIC ID			1
	Topology		Processor ID 0, Core ID 1, Thread ID 0
	Type			02004009h
	CPUID
	0x00000001		0x00100F43	0x01040800	0x00802009	0x178BFBFF
	MSR 0x0000001B		0x00000000	0xFEE00800
	MSR 0xC0010068		0x00000000	0x00000000
CPU Thread 2
	APIC ID			2
	Topology		Processor ID 0, Core ID 2, Thread ID 0
	Type			02004009h
	CPUID
	0x00000001		0x00100F43	0x02040800	0x00802009	0x178BFBFF
	MSR 0xC0010062		0x00000000	0x00000002
	MSR 0xC0010071		0x00800000	0x48024005
CPU Thread 3
	APIC ID			3
	Topology		Processor ID 0, Core ID 3, Thread ID 0
	Type			02004009h
	CPUID
	0x00000001		0x00100F43	0x03040800	0x00802009	0x178BFBFF
Storage
USB Device			USB Mass Storage Device, class=0x00, subclass=0x00, vendor=0x1058, product=0x1100
USB Device			USB Human Interface Device, class=0x00, subclass=0x00, vendor=0x045E, product=0x0084
Graphic APIs
API				NVIDIA I/O
API				NVIDIA NVAPI
Display Adapters
Display adapter 0
	Name			NVIDIA GeForce 9800 GT
	Revision		A2
	Codename		G92
	Technology		65 nm
	PCI device		bus 1 (0x1), device 0 (0x0), function 0 (0x0)
	Vendor ID		0x10DE (0x0000)
	Model ID		0x0614 (0x0000)
Trimmed the ACPI
This problem only recently began? How old is the fan? Try replacing it with another one, or temporarily connect it directly to the PSU (if it came with a molex adapter).
Uninstall Speedfan and use only whatever Asus sent with that mobo (original AI Suite perhaps?)
The problem began about a week ago. The whole computer is 2 years old. All the parts were bought together and put together myself.
Ok, I completely disconnected that fan from the power supply.
The sound is gone (of course).
Core Temp is 111°F
I will look into buying a new fan but honestly I don't feel like I'm short on fans. If you look at my case (http://www.newegg.com/Product/Product.aspx?Item=N82E16811156063) it already comes with 4 fans.
So that's 3 I'm left with + the heatsink.
I've never had a fan go bad but do you think that the cause of it slowing down like that was from a setting on my computer or did the thing just die?
Looks like I'll be looking into replacing that fan. I should have just unplugged it along time ago. For some reason I thought the fan was acting weird because I was messing with SpeedFan and messed up the setting for it.
I have an extra fan in an old computer case in storage I'll try hooking it up to this machine and see if I still get the same issue tomorrow.
Appreciate the help everyone I'll update after I do that.
Well I haven't gotten a chance to test out another fan yet but earlier today my GPU and core both got to 144°F and one of the fans got really loud.
I've been getting BSOD a lot more frequently than normal too. It's almost always been giving me the ntfs.sys error message on these blue screens lately.
I ran memtest and I did find errors on both sticks of RAM I have which are G.skill so they have lifetime warranties. Do you think they are the cause of all this?
What brand and model (not just wattage) is your PSU?
Bad RAM will cause BSODs, but not make fan speeds vary. A bad PSU can do all sorts of things, including killing other parts (like the RAM).
Another fan getting loud could just be your system trying to cool itself. Make sure you have good airFLOW through your case (typically front to back; a side fan is usually an intake and a top fan should be an exhaust). Make sure your front fan is an intake.
Your PSU is fecal. I would not trust it to reliably power computer components.
Your system with a 9800GT can be powered by a 380W Antec or 400W PC Power & Cooling.
Edit: It is amazing how many computer problems can ultimately be traced to a bad PSU.
Why do you say that it is a bad CPU? At the time I bought it with the other parts it seemed like it had decent wattage and good reviews.
Are you saying the psu isn't capable keeping my computer stable? I was actually wondering if it might be the psu too.. but it's not like I have top of the line parts running under it
Not the CPU...the PSU...Power Supply Unit. Raidmax is not known for quality, in fact it was one of their units featured in an old Corsair clip that died well under its labeled rating (they showed three dying in that clip, all with sparks and smoke). You may not be stressing yours in a way that would kill it outright like that, but it was likely built without proper EMI filters, and using substandard parts such that it is not capable of producing clean and stable output voltages.
That was a typo sorry I meant to say PSU.
There's not really any way to find out if the PSU is the issue unless I buy a new one and swap it right? Don't have any higher watt PSUs laying around unfortunately.
Ok. I don't think I have any higher quality ones either since they are stock. I thought I was buying a good one when I got that raidmax one lol.
I will look into finding a new one. How do the raidmax psu's have such good reviews on newegg? That's normally what I go by for hardware that I don't know exaclty what to look for.
IMHO (there are a few others), the best sites for competent technical PSU reviews are HardwareSecrets.com and Jonnyguru.com; close behind (good load testing, but may not dissect) are HardOCP.com and Anandtech.com. Newegg PSU reviews are meaningless consumer fluff. Someone will buy a 500W Raidmax, Coolmax, Logisys, Diablotek, Apevia, CM, etc; then put a 200W load on it and write a glowing review.
HardwareSecrets also has some good tutorial articles.
