In a Phanteks Eclipse P400S, would a rear mounted 120mm radiator with two 140mm fans in the front be able to provide enough airflow and positive pressure?
I'm specifically considering the NZXT Kraken X31 120mm radiator for the rear exhaust of the case and two Be quiet! SilentWings 3 140mm PWM HighSpeed fans in the front for intake.
The Eclipse P400S comes with detachable top panels (and dust filters) which I consider removing to allow air to flow through the top of the case. Alternatively, I could buy another pair of SilentWings 3 140mm PWM fans and install in the top, but I think that would be unnecessary.
Another alternative, and the most popular one I guess, would be mounting a 280mm radiator in the front and have a 120mm exhaust fan in the rear. However, I have heard that this specific case is rather restricted when it comes to airflow in the front. Corsair and Fractal Design seem to have this part figured out much better than Phanteks.
Planning to run the i7 7700K and Palit GeForce GTX 1080 Super Jetstream in the setup.
But, any thoughts or recommendations?
