Question REAR or Front Panel Audio? Which is louder and better Quality?
axelrose
17
I have a MOBO Gigabyte X470 AORUS Gaming Ultra and need to know if the Read audio outputs or the Front audio output is Louder or Better quality for a Headset?
If so, what color on the back panel would I connect the headset audio to?
Also what output color would I plug to for the headset MIC to on the back panel?
Thanks!! 💩
Try and keep to one thread, if you are posting about the same hardware related issue.
Id say the rear would be better. The front panel is normally connected to the mobo by a thing cable, where's as the rear is going directly to the sound device through the mobo.
Some audiophiles will be able to tell you the difference between sound quality etc.
