rear pc audio
gabitg103
9
hi, i recently bought new motherbored, gigabyte aorus gaming 5 z270x, and the problem with it is that the audio on the front panel is much better than on the rear, and i want to use just the rear jack, is there any cards or extantions that i can use so i can plug that front audio to the back, i mean just to move the front audio panel to the back of the pc.
Are you using low quality speakers? I too had this problem, just got some klipsch promedia 2.1 thx speakers and I'm loving it. I was getting all sorts of interference and low quality sound no matter what I did. I thought about getting a sound card as well, turns out I just needed some good speakers.
Latest posts
