Rear USB problems
Silver79
22
Alright so I am having problems with my USB ports in the back. When I play a game that's intense on my hardware like Planetside 2, Fallout 4 on ultra, MGS V on ultra, etc. It also happens whenever I upload anything or when I download something large.The USB's will essentially reset where they turn off 3-5 seconds then come back on. It happens pretty frequently rough estimate of 10 times per an hour. I would normally just ignore it however my keyboard and my WiFi adapter are in the rear. So as you can tell it's a major problems when I'm playing games. Oddly enough it doesn't do it on a game like Black Ops 3. I've already gone through and changed my power management plans for USB's and set the adapter to maximum performance. I also went into the hardware and unselected "Allow this device to be turned off "
Specs:
http://prntscr.com/96dfrm
http://prntscr.com/96dg3d
http://prntscr.com/96dgb4
http://prntscr.com/96dgh5
The keyboard is a Razer deathstalker
The adapter is a Linksys ac1200
I had the problem for a little when I first got the PC from cyberpower. It eventually went away for awhile and I put in some upgrades. Only recently it started doing it again when I started playing fallout 4
