P pcloverakagameboss Prominent Apr 27, 2017 70 0 630 Aug 22, 2017 #1 My new PC build won't boot my mobo has a led that lights up for different problems and it said my CPU is the problem Motherboard : msi z270 gaming pro carbon CPU:i7 7700k
Solution helpstar Aug 22, 2017 be sure that no CPU socket pins of the motherboard are bent and the CPU fan from the cooler is plugged in too. The black cap of the CPU socket was removed from the motherboard before finally installing the CPU? https://eteknix-eteknixltd.netdna-ssl.com/wp-content/uploads/2015/07/socket11.jpg
eWOOD29 Reputable Jan 11, 2016 88 0 4,660 Aug 22, 2017 #2 In the top left of your board there should be connectors that say CPU on them. Make sure those are both plugged in. Upvote 0 Downvote
alexoiu Titan Nov 1, 2012 39,817 250 126,990 Aug 22, 2017 #3 Check http://www.tomshardware.co.uk/forum/261145-31-perform-steps-posting-post-boot-video-problems See if helping. Upvote 0 Downvote
P pcloverakagameboss Prominent Apr 27, 2017 70 0 630 Aug 22, 2017 #4 The CPU power is plugged in Upvote 0 Downvote
Phillip Corcoran Titan Moderator Sep 7, 2013 26,107 912 120,140 Aug 22, 2017 #5 If not POSTing, motherboard may need BIOS updating to support Kabylake CPU. https://www.msi.com/Motherboard/support/Z270-GAMING-PRO-CARBON.html#down-bios Upvote 0 Downvote
helpstar Titan Dec 25, 2012 14,854 1,110 84,840 Aug 22, 2017 Solution #6 be sure that no CPU socket pins of the motherboard are bent and the CPU fan from the cooler is plugged in too. The black cap of the CPU socket was removed from the motherboard before finally installing the CPU? https://eteknix-eteknixltd.netdna-ssl.com/wp-content/uploads/2015/07/socket11.jpg Upvote 0 Downvote Solution
P pcloverakagameboss Prominent Apr 27, 2017 70 0 630 Aug 22, 2017 #7 The black CPU cover was removed all the plugs are plugged in I think it needs bios update Upvote 0 Downvote
helpstar Titan Dec 25, 2012 14,854 1,110 84,840 Aug 22, 2017 #8 That´s a problem then, because your motherboard doesn´t have a feature like BIOS flashback. Did you clear the CMOS by jumper yet? Upvote 0 Downvote
