Question Reboot and select proper boot device problem.
Apr 20, 2019
13
I just assembled my new pc components outside the case. I have an X570, 3600x cpu, and a rx5700xt. I also have an m.2 sad and a SATA hard drive I stalled. When I start my system up all that comes up is a message “Reboot and Select proper Boot device or insert boot media in selected boot device and press a key.” What do I do to resolve this and get to the bios.
Jul 27, 2019
12
there should be a prompt to get in the bios before hand or the cpu might not be supported on the motherboard, AMD do boot kits where they send out [censored] cpu's for free to update the moba for the new ryzens as they cant be detected by some mobos
Jul 27, 2019
12
there should be a prompt to get in the bios before hand or the cpu might not be supported on the motherboard, AMD do boot kits where they send out shit cpu's for free to update the moba for the new ryzens as they cant be detected by some mobos
but also on that, once your in the bios, then u go through and select what SSD HDD u want to boot of
Apr 20, 2019
13
But it’s also a brand new motherboard with the brand new chipset for the new and processors. There would be no reason for an update.
Jul 27, 2019
12
are u sure theres no prompt for the bios before it says about the boot device? try spamming F2 or F12 constantly after turning it off and on
Phillip Corcoran
Nothing to do with BIOS updates --- the CPU is obviously already compatible with the BIOS and POST is successful, otherwise you wouldn't get that boot device message.
The BIOS/UEFI setup utility does not normally appear automatically, you have to press the specific key which is usually shown on the splash screen eg "Press DEL for setup". (Mine says "Press F2 for setup").
If you don't press the required key, the PC will simply proceed to the boot stage, which is what is happening in your case.
